BrianJ44
Oct 08, 2023Guide
Orbi RBR50
Orbi App 2.30.1.7 IOS installed...my RBR50 Router shows up on the APP but the 3 RBS50 Satellites do not. The device however shows all 25 connected devices. I did turn off Private WIFI address on my I...
- Oct 10, 2023
If the RBS and RBR are all on same version of FW, then your good to go.
I might power off the ISP modem, RBR and RBS for 1 minute then back ON.
Oct 08, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router and RBS been performed since last update?
Turn off and unplug modem.
Turn on RBS, computers and rest of network.
BrianJ44
Oct 09, 2023Guide
Hi Furry e38...thank you so much for the response. I apologize I did not respond sooner as I lost my entire Wi-Fi for a day. I followed your steps and unfortunately the Orbi Router would not re-connect to the Wi-Fi. I have the Orbi Router set up in Router Mode and hooked in directly with Verizon Wi-Fi and I no longer use the Verizon modem. I ended up having to factory reset everything and it still did not work. I had a new Orbi RBR50v2 that I had purchased on sale as a backup years ago. I ended up hooking that up and everything is now working including the Orbi APP... go figure!! My question is, my 3 satellites are all updated to V2.7.5.4. Currently the new router is using V2.7.5.4. I can manually update it to V2.7.5.4 but wonder if that is what caused the problem with the old Orbi although it was working for over a year with the latest update. Your thoughts appreciated.
- FURRYe38Oct 10, 2023Guru - Experienced User
