BrianJ44
Oct 08, 2023Guide
Orbi RBR50
Orbi App 2.30.1.7 IOS installed...my RBR50 Router shows up on the APP but the 3 RBS50 Satellites do not. The device however shows all 25 connected devices. I did turn off Private WIFI address on my I...
- Oct 10, 2023
If the RBS and RBR are all on same version of FW, then your good to go.
I might power off the ISP modem, RBR and RBS for 1 minute then back ON.
Oct 09, 2023Guru - Experienced User
does it show if you log in through the browse and not the app?
what modem/gateway is the router connected to?
Are the satellites connected through a switch? Are they wireless? Wired?
A little more details help
BrianJ44
Oct 09, 2023Guide
Hi Plemans, thank you so much for the response...here is what I communicated to Furrye38...thank you so much for the response. I apologize I did not respond sooner as I lost my entire Wi-Fi for a day. I followed your steps and unfortunately the Orbi Router would not re-connect to the Wi-Fi. I have the Orbi Router set up in Router Mode and hooked in directly with Verizon Wi-Fi and I no longer use the Verizon modem. I ended up having to factory reset everything and it still did not work. I had a new Orbi RBR50v2 that I had purchased on sale as a backup years ago. I ended up hooking that up and everything is now working including the Orbi APP... go figure!! My question is, my 3 satellites are all updated to V2.7.5.4. Currently the new router is using V2.7.5.4. I can manually update it to V2.7.5.4 but wonder if that is what caused the problem with the old Orbi although it was working for over a year with the latest update. Your thoughts appreciated.
In response to your question...I have my OrbiRBR50v2 set up as my Router going directly to Verizon Wi-Fi. I no longer use their modem. My satellites, 3 of them, RBS50 are wireless. As I told Furrye38 the Orbi APP now works and my question is whether to manually update the new Router. Your thoughts appreciated.
