BrianJ44
Oct 08, 2023Guide
Orbi RBR50
Orbi App 2.30.1.7 IOS installed...my RBR50 Router shows up on the APP but the 3 RBS50 Satellites do not. The device however shows all 25 connected devices. I did turn off Private WIFI address on my I...
- Oct 10, 2023
If the RBS and RBR are all on same version of FW, then your good to go.
I might power off the ISP modem, RBR and RBS for 1 minute then back ON.
