Fattony81
Dec 22, 2023Follower
Orbi RBR50
Hi My original setup was Orbi router and a RBS50 satellite. I’ve now purchased a new satellite and attempted to add it to the network, I’ve defaulted it and followed the app to add a new satelli...
CrimpOn
Dec 22, 2023Guru - Experienced User
According to this spreadsheet, Netgear does not distinguish between v1 and v2 Orbi routers:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
The only significant differences between the two routers are:
- V2 does not include a USB port (because the original plans to make use of the USB port were quietly abandoned).
- V2 has less RAM and memory (because in practice customer routers never used the entire capacity).
The CPU, radios, and other components are identical.
However, you may be onto something. The original RBS50 from 2016 says thisL
And the RBS50v2 satellite says this:
I have always assumed that when the original Orbi product was released back in 2016, it was the only product in the mesh WiFi portfolio. So, the only device an RBS50 could connect to was the RBR50. Netgear is not famous for going back and revising product literature.
By the time the v2 product was released, the portfolio included more mesh WiFi routers, including the RBR20 and RBR40.
Does this mean that an original RBS50 satellite cannot sync with the newer RBR50v2 router? I certainly hope not.
I am seriously not a fan of the Orbi 'app' and prefer to do anything serious with the WiFi system using the Orbi web interface. Adding a satellite is discussed on page 12 of the user manual:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
