Cabinew
Sep 29, 2020Guide
Orbi RBR750 Speed Test connection failed
I have the Orbi model number RBR750 (number on the bottom of device), but the box says AX4200 RBK753S. It is the WiFi 6 robust Smart Home Tri-Band Mesh WiFi 6 system from Costco. I could not find it i...
gchin3
Sep 29, 2020Initiate
You're not alone in this. This appears to be an issue with the Orbi App. Netgear support is not very responsive; if you need a warranty repair, it will take weeks to get something resovled -- and they'll not honor the warranty period...without you paying for their phone support to tell you that their equipment is broken.... I would suggest that you run the speedtest.net (or fast.com) on a browser to check your network performance.
Tried so far:
Rebooted router.
Rebooted cable modem.
Deleted Orbi app; re-installed Orbi app.
Someone suggested going to settings and looking for enabling "Orbi"...however, I don't see what they're talking about....
I've sent e-mail...nothing.
Good Luck.
capiture
Sep 29, 2020Guide
Right - an absolute s..t show at NETGEAR!
I wanted $1400 on 3 routers and 1 modem and what a waste. Customer service is non existent.
Regarding speed test: sure you can do tests on your phone using browser, but that’s not same as the Orbi App. Because that tells you speed from modem to your connected router. Thus the speed of your internet provider.
Doing test on a browser has degradation depending on many factors on your device and distance.
- CabinewSep 29, 2020GuideThanks for the feedback. Like many others. The speed test worked great for the first couple of weeks, then all of the sudden it stops working. I wonder if it has something to do with firmware upgrades. I am not that tech savvy, but hope hope they have a simple solution.
- Christian_ROct 02, 2020NETGEAR Employee Retired
Hello Orbi Users,
For those still experiencing issues, please send me a private message with your email address and phone number. I'd like for our support team to reach out for further investigation.
Christian
- CabinewOct 02, 2020GuideJust sent you a private message with my email so we can try to resolve my issue.
- bcarrion2Jan 10, 2021Aspirant
Continued failure for internet speed test. Rebooted multiple times
- scngOct 18, 2020Initiate
yes, speed test problem as described.
- MrsHudsonNov 14, 2020Initiate
We had just updated our internet speed along with our Orbi system a few days. I had ran the speed test on my phone through the app earlier today without any issues, a few hours later went to test the speeds again and now get a connection failed response. We rebooted the whole system Router and all Modems. I refuse to reinstall my system after having to go around me house and relink all my wifi outets, garage system, TVs and such back into the orbi even though it should have relinked everything once I renamed and gave the same password as the last orbi system. Nothing relinked like it was supposed to.
Nothin changed in the last hours when first testing speed and later testing speed.
- capitureNov 15, 2020GuideSame issue - months and no response or support from awful NETGEAR staff. Zero care for customer.
NEVER again will I buy NETGEAR products.
NEVER!
