Cabinew
Sep 30, 2020Guide
Orbi RBR750 Speed Test connection failed
I have the Orbi model number RBR750 (number on the bottom of device), but the box says AX4200 RBK753S. It is the WiFi 6 robust Smart Home Tri-Band Mesh WiFi 6 system from Costco. I could not find it i...
Markyyeomans
Nov 26, 2020Tutor
Having same issue as all - new Orbi WiFi 6 - all set up abs testing speed successfully for first 36hrs and then the Speedtest stopped working and states “connection failed.” Have reset the routers as advised and reinstalled the app but the speed test still doesn’t work..... please help. Have had 3 chats with the help desk but got nowhere unfortunately
capiture
Nov 26, 2020Guide
I tell you - NEVER AGAIN will I get NETGEAR.
