Cabinew
Sep 29, 2020Guide
Orbi RBR750 Speed Test connection failed
I have the Orbi model number RBR750 (number on the bottom of device), but the box says AX4200 RBK753S. It is the WiFi 6 robust Smart Home Tri-Band Mesh WiFi 6 system from Costco. I could not find it i...
angrylocal
Nov 22, 2020Aspirant
1) Cannot get the ORBI IOS app to do a speed test. Could do it before, re-installed app, same message, failed connection.
2) Ethernet port on satellite not working
3) I have 1G FTTP service, cannnot get near that on WiFi max is 500 in same room, not impressed. 5G conection between base and satellite shows good. Using WIFI 6 antenna on testing device.
angrylocal
Nov 26, 2020Aspirant
Update on factory reset.
Factory reset the ORBI router and I can now do speedtests again. Testing of wired connection looks good and within expectations. The wired connection issue was an issue on my MAC and i get an IP address (fixed prior to reset)
Wireless speedtests with WIFI6 devices less than expected, using Ookla App, Speedtest.net, ISP providers webesite and various speed test servers.
Thanks,
- ssowardNov 26, 2020InitiateGlad to hear there’s a way to get this to work again, but as most people stated, it goes out after a short period. I’m ready to take this back and get the eero mesh.
