Cabinew
Sep 29, 2020Guide
Orbi RBR750 Speed Test connection failed
I have the Orbi model number RBR750 (number on the bottom of device), but the box says AX4200 RBK753S. It is the WiFi 6 robust Smart Home Tri-Band Mesh WiFi 6 system from Costco. I could not find it i...
Cabinew
Nov 26, 2020Guide
I did the reset on the phone with a net gear agent. I am sorry I don't remember the process. I would recommend calling their service team. Sorry I couldn't be of more help to you.
Markyyeomans
Nov 29, 2020Tutor
Went through a length process of resetting everything with agent and Speedtest worked again, ....then after 36 hrs is stopped. So clearly there isn’t a long term fix for this issue. Can someone from netgear acknowledge there is a issue and look for a fix in the next update? Someone should let Ookla know as it reflects badly on them
