dancoulson
Jun 03, 2022Follower
ORBI RBR750
I still can't connect to my orbi rbr750 . I have a static IP assigned and don't want to reset the orbi and risk bricking the system. I have three satellites and want to add two more.
Jun 03, 2022Guru - Experienced User
You'll need to contact NG support:
https://my.netgear.com/support/contact.aspx
Otherwise a factory reset and setup from scratch will be needed to re-gain access using a wired PC and web browser.
Good Luck.
