DAC1970
May 21, 2022Initiate
Orbi RBR850 not connecting in app
How do I get the fix for this issue? It’s been weeks that I am unable to get the app to connect to router. Thanks!
May 21, 2022Guru - Experienced User
If you're in the forum for the orbi AX, you'll notice a warning at the top of the page with an issue with the app
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/bd-p/en-home-orbi-ax
some are waiting on the fix. Others have tried a factory reset and installing with the browser to fix. Kind of up to you which route you want to go.
