Lizabqts
Apr 09, 2023Aspirant
Orbi-rbr850 not showing devices and not network map
Orbi-rbr850 not showing devices and not network map. Did 2 reboot and a Full reset stayed the same not showing anything. I think the app is messed up.
- Apr 10, 2023
Any progress on this? Let us know.
I passed this on to NG for review yesterday. Seeing that some users have started seeing it work again.
Geojos
I had the same problem today, and fixed it.
Google play doesn't have the updated version for the Orbi app.
I just removed the app and downloaded the newest version 2.25.0.2813. Works correctly and stable.
I used apkpure since Google play doesn't have it up to date.
Lizabqts
Just tried show map but no devices.
- GeojosApr 09, 2023AspirantYa I had that same problem until I got home and reset to factory, setup orbi, then backed up configuration file.
- LizabqtsApr 09, 2023AspirantI did that and nothing. I submitted a report. Low hopes. Might be a bug on the app or needs to be updated.
- GeojosApr 09, 2023AspirantThe old app firmware shows -1 devices under device manager and network map never worked.
The newer version it showed 0 devices and network map works lol
