VerneArase
Sep 28, 2020Apprentice
Orbi RBR850 QoS Spped Test Fails
Anyone know how to get the speed test working on the RBR850? Every time I try to use it it just hangs. It's less important now that I have gigabit service, but when I had 300 mbps service...
Mar 23, 2021Guru - Experienced User
Been working here for me on v12 and using a CM1200 modem:
jsrichie
Mar 23, 2021Tutor
- jsrichieMar 23, 2021Tutor
So I have posted the response 5 times and each time it is removed.
Why?
- FURRYe38Mar 23, 2021Guru - Experienced User
What text are you using?
Yea I placed it in all text cleaned with notepad. Yet still pulled.
So It my only assumption that the data posted is in some way not acceptable despite its only the details of the issue.
So with that it looks to be that Netgear does not wish to solve the issue with the flagship device for home use. Nor have it in the light.
yet Ill try again in a smaller chunk
