VerneArase
Sep 28, 2020Apprentice
Orbi RBR850 QoS Spped Test Fails
Anyone know how to get the speed test working on the RBR850? Every time I try to use it it just hangs. It's less important now that I have gigabit service, but when I had 300 mbps service...
Mar 27, 2021Guru - Experienced User
So you have an ONT connected to a CM series modem? Can the CM modem be removed when using the ONT?
Seems like your configurations could be effecting the RBR. Most RBRs should connect to a ONT directly or a CM series modem if the modem is fully coax connected. My RBR850 is connected directly to my CM1200 since last year. No ONT present. I have no probems with QOS or speed issues.
You'll need to keep in contact with NG support about this. You may have a faulty system.
I would also not use the switch as well. This may introducing problems in to the mix. I would connect the RBR in AP mode directly to the R series router in that configuration.
The CM series modems do not have DHCP services do AP mode is not a valid configuration for the RBR.
jsrichie
Mar 27, 2021Tutor
You dont have fiber then, Optical Network terminal.
The configurations have been all explained in detail to NG .
They are not posted here because they keep removing the gory details
I surly not dropping cash on a Netgear CM with coax
Put your device in AP mode drop a Switch in and I bet you get the same reaction.
It will not speed test both units.
There is also an auable click on the satellite
Im done with Netgear they have wasted to much of my time for his type of trivial issue.
The need to fix their spanning tree issues or give up.
I have already made the choice to move on and guess what back to lighting fast.
And well a hell of a lot better integration with the new vendor.
Bye Bye Netgear.
PS I Have a new ORBI system,324tp, 4 GC308E, and 4 GS110TPv3s, for personal use.
30 +GSM4230P's and a few XSM4348CS enterprise units.
Offers?
- jsrichieMar 30, 2021Tutor
yep promised a call at 0900 to 1000 this morning and the call never came,
So Netgear has again had me SIT around waiting for a call which never comes.
WHY
