CrazyMick
Apr 10, 2023Aspirant
Orbi RBS960 and login credentials
Regarding the managing of my mesh system once I have things setup. I have the Orbi App for iphone. I can login and see everything just fine so far. I've heard that if this app gets updated my login c...
- Apr 10, 2023
Correct. If you change the routers admin log in PW on the RBR using the WEB UI, the Orbi app will not see this change so you'll need to input the new PW once you lunch the Orbi all.
CrazyMick wrote:
Thanks Furry,
So if I login to the Orbilogin.com web interface and I change my password for that login. Does that new password follow through to the Orbi App? Meaning the next time I use the Orbi App it will ask me to login and I will need to use admin and the new password?
CrazyMick
Thanks Furry,
Apr 10, 2023Guru - Experienced User
CrazyMick wrote:
Thanks Furry,
