TerryMcCoy
Oct 05, 2022Aspirant
ORBI remote access
We have 3 homes and have ORBI systems in each home. Before I turned on remote access, the ORBI app would control each house once the appropriate WiFi was recognized. Is there a way to use the ORBI app...
Oct 05, 2022Guru - Experienced User
What Orbi model systems do you have?
Are all 3 systems registered to and under your Netgear profile account?
What brand and model modems are the systems connected too?
FW version as well thats used on each system.
Do you see each orbi system in the Orbi apps menu under the 3 horizontal lines top left corner of the app?
TerryMcCoy wrote:
We have 3 homes and have ORBI systems in each home. Before I turned on remote access, the ORBI app would control each house once the appropriate WiFi was recognized. Is there a way to use the ORBI app to control all three? I turned on remote access while in one home and now I cannot access the other ORBI systems.
- TerryMcCoyOct 05, 2022AspirantI have 2 ORBI RBK50 systems and one RBK20 system.
All 3 are registered and should be under my netgear profile.
One RBK50 is connected to an Assus modem, one RBK50 is connected to a Motorola and the RBK20 is connected to an ATT modem.
When I click on the 3 lines in the upper left corner of the ORBI app I only see the RBK20.- FURRYe38Oct 05, 2022Guru - Experienced User
Get you get the model #s of the modems please.
- KevinLiTOct 05, 2022NETGEAR Moderator
Hello TerryMcCoy,
Welcome to the NETGEAR Community!
I understand you are having issues with accessing your Orbi Mesh systems from a different network.
Have you ever registered the RBR50's in your Orbi app before attempting to access those devices remotely?
Best,
Kevin
Community Team
When I set up each RBK50 I used the Orbi app. When I was in each residence, the app automatically. When in the location with the RBK20 system I turned on remote access and now when I open the app it only finds the RBK20 and its one satellite. What do I do to have the app find the RBK50 system in the house I’m in now? Do I set up a new Orbi system?
