cayollc
Feb 20, 2020Initiate
Orbi Router(RBR50)
I am new to orbi system but I was able to install and its working fine. The only problem is that the app always says internet - offline -and the router shows a magenta dot in the app all the time. Th...
Feb 20, 2020Guru - Experienced User
do you have it setup in a double nat?
What I mean is what modem do you have it connected to? Does it have an integrated router as well?
https://kb.netgear.com/30186/What-is-Double-NAT
If so, you can either put the modem/router in passthrough/modem only mode or you can put the orbi in AP (access point) mode.
- cayollcFeb 20, 2020Initiate
Yes i fully understnad your explabntion and thats exactly what is happening. I need to find someone to eliminated the first modem and how to do that. Thank you so much!
- plemansFeb 20, 2020Guru - Experienced User
You need a modem. They make modem only devices. And some modem/routers have a modem only modem or passthrough mode.
What modem are you using?
Or you can just put the orbi in ap mode. It does disable some features of the orbi but wifi/ethernet will all still work. It leaves the modem/router functions all intact on the modem.
- porschev968Feb 21, 2020Aspirant
I am having similar problem... app is showing the one Satellite as purple (magenta) with devices connected in the network map. However, the actual satellite is working with no puprle light and all connected devices are working perfectly. I am running in AP mode behind Verizon router. Thanks.
