Ob0505
May 16, 2019Aspirant
Orbi satellite does not show up on network map when daisy chained to another satellite
When i go to the orbi app on my phone only the satellites connected to the router appear on the network map. Does this mean my satellite that is daisy chained to another satellite that does not show ...
May 17, 2019Guru - Experienced User
Is it working?
What models of your satellites are you using? Firmware on your devices?
Are you sure it didn't just switch from daisy chain to a star topology?
If you log into the device on the broswer, does it show its connected through the attached devices list?
Bugs do happen within the app/browser so its always good to double check things.
- Ob0505May 18, 2019Aspirant
It is RBR40 model. I can see the daisy chained satellite connected to another satellie on the device list. The daisy chained satellite DOES NOT show up on the network map as connected to the router. Is this normal?
