GOING-ORBITAL
Aug 25, 2024Aspirant
Orbi satellite RBS50V2 no longer showing up in Orbi AP
I have had my Orbi RBR50V2 system for over 2 years and now all of a sudden the Orbi satellite RBS50V2 does not show up in Network map. Any suggestions.
CrimpOn
Aug 25, 2024Guru - Experienced User
It would be helpful to know if the satellite appears on the Orbi web interface, Attached Devices page.
See page 98 of the User Manual:
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
On the Device Manager screen, do any devices appear to be connected to that satellite?
If you power the satellite off and then back on again, does the light at the top turn Blue for 3 minutes or magenta?
GOING-ORBITAL
It shows that the satellite is attached and it does show that there are devices running off of the satellite. It’s just not showing up on the app.
- CrimpOnAug 26, 2024Guru - Experienced User
Does not give a person much confidence in the 'app'. This has been reported on the forum a number of times. I do not recall anything that the user can do to change it.
