dhombesh
Jul 10, 2019Initiate
Orbi satellite showing connected on orbilogin but not in app
I have the RBK50 system which has been working well for a few months with the satellite connected to the router via wifi. My house is wired with Cat5e and today I connected the satellite to the route...
dhombesh
Jul 29, 2019Initiate
This is very helpful. Thanks.
So based on your tests it appears that once hard wired, all devices will die connected only to the router and all satellites will show as ‘offline’ in orbi app.
Doesn’t Netgear think that the community should be informed in order to minimize confusion?
Evgizo
Jul 30, 2019Initiate
Correct. All hard wired satellites will show as ‘offline’ in orbi app but in fact they are just connected to the orbi router. The ‘offline’ status is confusing but technically correct as they have dropped the function being a satellite and extending the router signal instead.
Your devices will connect to the closest unit (or whichever gives the strongest signal) but in orbilogin you will only see them connect to the router. As I said, you can test whether a device is connected to the router or satellite by using the orbi app on that device.
To be honest, there are quite a few things that Netgear should fix regarding both orbilogin and the orbi app. I hope they will get to the bottom of it in the near future.
- docincaliDec 26, 2019Aspirant
I have the same issue. Unfortunately, my FIOS ONT is in the garage on one end of the house and it is Ethernet only. I have the rbk53 AC3000. I have 5000 sq ft house with huge walls and my satellites were getting horrible reception and a huge drop off in speed. I have gigabit fios with frontier. So, I bought some bonded 2.0 moca adapters from actiontech off amazon and connected my fios ont with the arris modem and then to the moca. So then I moved the router to the middle of the house and connected it via moca/coax and then I figured why not hardwire a satellite in an extreme corner of the house. The problem is the coax's through the house are moca'ed to the original modem but I decided to connect a satellite anyway and....
The satellite on orbilogin shows it as online and hardwired....on the app it shows up with a solid line and purple.
When I'm on the app by that satellite it doesn't recognize that I'm on my orbi network even though my WiFi shows the same SSID and I never chose another network but speed tests are equivalent to being next to the router.
All devices on the app show connected to the router only.
So what is described above is exactly what I have going on. I just purchased the AX6000 and plan to use my older satellites hardwired with it because I have read that this is possible.... I assume this will be the same sceneraio.
My question is is there a better to wire and place everything. It boils down to should I place my router in the garage and moca satellites to the router or should I place my router in the middle of the house via moca and have all the satellites wired in via moca back to the modem as well?
Thanks in advance!
