Ozonshak
Feb 22, 2024Star
Orbi satellites no longer showing up on Network Map
Hello. I have an Orbi Mesh RBR750 with 2 satellites. The Orbi App no longer shows my satellites as connected (or any connected devices), even though i'm pretty sure they are fine. I restarted 1 of...
- Feb 22, 2024
Got it working again. Looks like it needed yet another router restart (only the router). Once I did that, the satellites showed up in the app and online. Thanks for the help!
Ozonshak
Feb 22, 2024Star
Thanks. When I check the router for new updates it is telling me "No new firmware is available at this time". Are you sure "7.2.6.21" is the correct most recent version? I'm on v4.6.14.3 for RBR750 and I just updated that a couple of weeks ago.
Is there a way to update the satellites or does that normally happen with router updates?
As for the browser GUI, what is the typical way to access that? I never use that - just the app. I can certainly check there just to make sure this is isolated to the app.
Feb 22, 2024Guru - Experienced User
There's a version of the RBR750 that has the RBS350 satellites connected to it. Its more than likely on a different firmware but I wasn't sure what version satellites you have. That kit would be the RBK653 and is on the lower version that you're on. So it depends on what actual orbi kit you have.
If you're connected to the orbi, just go to orbilogin.net or routerlogin.net or you can use its IP address
- OzonshakFeb 22, 2024Star
So, the web site shows the same thing as the app. The satellites are showing up as "connected satellites", but say "Disconnected" in the "backhaul status" column. Plus, I'm only seeing my 13 devices that are connected to the router. Nothing is showing related to the satellites. But, again, I think everything in the house is connected and working fine. My phone, for example, is using wifi right not, and my phone is not showing as connected in the app or online. But, I'm definitely using wifi and I'm probably hooked to 1 of the satellites.
This is the first time I've ever seen this happen. Any suggestions how to fix this? Since I seem to be on the latest firmware version, do I just need to wait until Netgear fixes it? Or is there any procedures I can follow to troubleshoot?
