Ozonshak
Feb 22, 2024Star
Orbi satellites no longer showing up on Network Map
Hello. I have an Orbi Mesh RBR750 with 2 satellites. The Orbi App no longer shows my satellites as connected (or any connected devices), even though i'm pretty sure they are fine. I restarted 1 of...
- Feb 22, 2024
Got it working again. Looks like it needed yet another router restart (only the router). Once I did that, the satellites showed up in the app and online. Thanks for the help!
Feb 22, 2024Guru - Experienced User
Which satellites do you have?
You could always try rebooting the system or factory resetting and reinstalling.
Ozonshak
Feb 22, 2024Star
