Jkitch21
Jan 16, 2023Aspirant
Orbi Satellites not detected on Orbi app
App shows 0 of 2 satellites. Checking directly with the router, it shows 2 satellites are connected. Network Map on the App, shows both satellites. Backhaul status, good on both. App also show...
CrimpOn
Jan 16, 2023Guru - Experienced User
App also shows both Orbi Satellites as inactive on App, devices.
Maybe it's because Monday is a federal holiday, but this seems inconsistent:
- App shows 0
- App shows both
When I bring up the Android Orbi app, satellites appear in only one place, the Network Map. They do not appear under "Device Manager" (because they are not devices. They are satellites.)
_Philosopher
Jan 20, 2023Aspirant
I'm seeing the EXACT same thing.
RBR40 -> RBS20 -> RBS20 - all wired connections.
- CrimpOnJan 20, 2023Guru - Experienced User
You are seeing that the Network map shows two satellites connected in a daisy chain? (which apparently is correct).
Or, you are seeing what "exactly"?
- _PhilosopherJan 21, 2023Aspirant
What I meant by “exactly” is that I’m seeing the same problem as the original poster. the details of which are:
- Home page of the iOS app - top right says number of satellites connected 0.
- Devices connected page of the iOS app does not list satellites.
- Network map of the iOS app shows both satellites connected.
- Devices page of the router’s web page (192.168.1.1) shows both satellites connected.
The answer to your question about daisy chain on the network map - no. The network map does not properly reflect that my satellites are connected as wired daisy-chained. The network map shows each satellite wired to the rbr40 router directly, separately.
