ronealwa
Jul 27, 2020Star
Orbi satellites not showing up on Network Map within Orbi mobile app
Orbi satellites no longer show up on the Network Map within the Orbi app. The satellites are fine, connected, and functioning great. They just no longer show up on the Network Map for some reason. Th...
Christian_R
Jul 30, 2020NETGEAR Employee Retired
Hello ronealwa,
You may need to update the Orbi app. Please reinstall the Orbi app.
Christian
- ronealwaJul 30, 2020Star
I just deleted the Orbi mobil app from my iPhone 7Plus, re-installed it and then launched it again. In the network app, only the router (RBR50) shows up. The 2 satellites do not. They used to, but now they don't. When I login to the Orbi router from my PC, I can see that both satellites are connected to the router with a "Good" signal and several devices are connected to them. So the satellites are functioning well, the mobil app just does not show them graphically within the Network App function.
Thanks
I meant to say the "Network Map" function of the Orbi mobile app instead of "Network App"
- Christian_RJul 31, 2020NETGEAR Employee Retired
Hi ronealwa,
Thanks for giving that a try. May you provide me with the current firmware version you have installed on your router along with the current Orbi app version you have installed.
Thanks,
Christian
