ronealwa
Jul 27, 2020Star
Orbi satellites not showing up on Network Map within Orbi mobile app
Orbi satellites no longer show up on the Network Map within the Orbi app. The satellites are fine, connected, and functioning great. They just no longer show up on the Network Map for some reason. Th...
Christian_R
Aug 05, 2020NETGEAR Employee Retired
Hi ronealwa,
May you revert to the previous firmware version below and let us know if you're able to see the satellites within the Orbi app.
https://kb.netgear.com/000061530/RBR50-RBS50-Firmware-Version-2-5-1-8
Christian
Warhammer1112
Aug 17, 2022Initiate
Mine just started doing the exact same thing, I power cycled both and the satellite works and is connected but on network map on orbi app it's saying not connected
- michelsannerNov 10, 2022Initiate
I have the same problem Firmware 2.7.4.24
- Jshaf1320Nov 19, 2022Initiate
I am having the exact same problem
