johnny_rumely
Jul 10, 2022Aspirant
Orbi satellites showing connected via ethernet but not on orbilogin
My orbi satellites are connected via ethernet, they show that they are connected on the app, but when i go to orbilogin they don't show at all, and on the app it doesn't show which devices are connected to each satellite, i believe i am getting the speeds, its just annoying how its not showing devices that are connected to each satellite, its almost like its acting as an "extender"
If i type in the IP address of the satellite, it takes me to the page, and it says that the satellite is up and running.
Im running in access point mode, i have made sure i have the latest firmware.
I have the RBKE963
Note: i believe the ethernet cables that i am plugging the satellites into are connected to a 24 port unmanaged switch, i have the orbi router plugged into my main modem/router combo, but im not sure what i need to do to connect the orbi router to the switch, i tried connecting it to the switch from the yellow port into the switch and the satellites were still doing the same thing with them not showing any connected devices.
I did read an article where someone mentioned that i should plug the orbi routers LAN port into the switch i will be trying that soon to see what happens.
No RepliesBe the first to reply
