Shahab
Jun 07, 2020Apprentice
Orbi Speed test discepancies
Hi, Has anyone else noticed discrepancies between the speed test in the Orbi app and running speedtests on other apps/websites such as speedtest.net? I have a 400 Mbps connection via Charter and pr...
- Jun 07, 2020The speed test in the Orbi app shows the hard wired speed to the Orbi router. Via sites and speed test apps, it would show your WiFi speed
Jun 09, 2020Guru - Experienced User
The other issue with it is that the orbi speedtest app function doesn't always pick the best server for testing.
So those with faster internet can run into issues when the speedtest function picks a server that's slower than your service.
Its nice for a quick test but the best results are found using a hardwired pc and using multiple tests to ensure you're fully saturating the server.
