Harry2022
Jan 05, 2022Aspirant
Orbi speed test does not match other tests. How do I increase the speed?
I just installed Orbi AX6000, RBR 850. When I use the app, I get a speed to over 900 Mbs. But on speedtest, I get only 100 Mbs. How do I improve the speed? I have 1 router and 2 satellites coveri...
- Jan 06, 2022
What brand and model # phone are you using?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Harry2022 wrote:
The speed test done using the Orbi app and the using Speedtest was done on my phone and it was using wifi.
I did not connect to either the router or the satellite using ethernet cable as I have all wifi devices at home and connecting with ethernet makes no sense for testing purposes.
My ISP is for 1GB. So even if signal keeps dropping with each satellite, I should get better speed in the test.
My house is 7,000 sq. ft. I have 1 router and 2 satellites of RBR850. Should I get 1 more satellite?
Harry2022
Jan 06, 2022Aspirant
Hey, Thanks for the detailed reply. Most helpful.
Makes sense.
Like you said, I will definitely not be able to interpret a heat map.
I wonder if there is a way of choosing 2.4Ghz or 5 Ghz on my laptop or phone. I can't seem to see any options that allow me to do it.
I guess I will keep experimenting with placement of the satellites and figure out the optimum placement.
Thanks again.
Harry
CrimpOn
Jan 06, 2022Guru - Experienced User
Oh, you could read a Heat Map just fine. It's obvious. Green is great. Yellow is (meh). Red is BAD.
It's making them that is a chore.
Many laptops have settings for their WiFi adapter that allow the user to 'lock' the laptop into one band. My Lenovo laptop offers six choices.
- 5GHz 802.11a
- 2.4GHz 802.11b
- 2.4GHz 803.11g
- 2.4GHz 802.11b/g
- Dual Band 802.11a/g
- Dual Band 802.11a/b/g
There are also settings for channel width and for "Preferred Band" (2.4G or 5G)
Smartphones I know less about.
