Harry2022
Jan 05, 2022Aspirant
Orbi speed test does not match other tests. How do I increase the speed?
I just installed Orbi AX6000, RBR 850. When I use the app, I get a speed to over 900 Mbs. But on speedtest, I get only 100 Mbs. How do I improve the speed? I have 1 router and 2 satellites coveri...
- Jan 06, 2022
What brand and model # phone are you using?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Harry2022 wrote:
The speed test done using the Orbi app and the using Speedtest was done on my phone and it was using wifi.
I did not connect to either the router or the satellite using ethernet cable as I have all wifi devices at home and connecting with ethernet makes no sense for testing purposes.
My ISP is for 1GB. So even if signal keeps dropping with each satellite, I should get better speed in the test.
My house is 7,000 sq. ft. I have 1 router and 2 satellites of RBR850. Should I get 1 more satellite?
Harry2022
Jan 06, 2022Guru - Experienced User
