millerre1959
Jan 26, 2023Star
Orbi Web Interface shows wired backhaul (correct) but Orbi Android app shows wireless (incorrect)
I have an Orbi RBKE963 WiFi 6E Mesh System with an additional RBSE960 WiFi 6E Add-on Satellite. All three satellites are connected to the router via Ethernet to support a wired backhaul. However, whi...
- Jan 27, 2023
Hello millerre1959,
Welcome to the NETGEAR Community!
I understand that you are not seeing the correct backhaul status on your Orbi app. Uninstalling and reinstalling the Orbi app have been proven to resolve issues like the one you are having. Please uninstall your Orbi app and then reinstall it.
Please keep us informed of your progress on this issue!
Best,
Kevin
Community Team
KevinLiT
Jan 27, 2023NETGEAR Moderator
Hello millerre1959,
Best,
Kevin
Community Team
- millerre1959Jan 31, 2023StarThank you for your suggestion! Before I had an opportunity to try it, the app was updated and the problem resolved itself. It now shows all three satellites as wired to the router.
