Beanbeany
Mar 17, 2023Aspirant
Orbis in different locations, different networks
I have 3 different homes, 3 Orbi routers, so 3 different networks. Can I use the Orbi app to control/see all 3 different networks with one log in? Every time I try to log in the Orbi app, it defau...
Mar 17, 2023Guru - Experienced User
Should be able to.
I have my home orbi and I setup one at my parents that I manage through the app using anywhere access.
- BeanbeanyMar 17, 2023Aspirant
“Anywhere access”? Is this a thing that should be enabled? Its just frustrating that sometimes it automatically logs me in, but most times it defaults to ADMIN user, which I cant change.
- FURRYe38Mar 17, 2023Guru - Experienced User
Yes AA would need to be enabled for all systems...however all systems would need to be associated and tied to your one NG profiled email account. Then they should all appear under the My Products list. You would have to take a snap shot of the RBRs serial number to tell what system your connecting to in the Product list. Orbi app doesn't offer a way to edit the name each system here.
Ah, ok, I feel like I need start all over again. Thanks for the help.
