gribeiro
May 13, 2023Aspirant
orbisetup refusing to connect
Since 1 day ago I detected some strange behavior on my network, tried to access the setup on Orbi app, no success. Tried the orbisetup.net also without success. Tried adding as a new system, no. And l...
- May 17, 2023Hey, just left a 100 minutes call with Netgear support team. It's working now. The solution was:
Keep the reset button pressed 30 seconds, while still keeping it pressed turn the router off and keep it without energy for other 30 seconds, then turn it on again always keeping the reset button pressed, and for another 60 seconds keep it always pressed. Only then, release it. It's finally working now. Thanks!
gribeiro
May 17, 2023Aspirant
May 18, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
