tunes
Aug 22, 2020Aspirant
Outdoor Orbi issues
So I have an outdoor orbi connected to my network, RBS50Y on firmare 2.3.5.32. In the orbi app under outdoor orbi it says 'off" but it shos as green and part of my network in the Network map. So is i...
CrimpOn
Aug 22, 2020Guru - Experienced User
Mstrbig wrote:
What does it show when you go to orbilogon.com?
That may be a typo. I believe that the Orbi DNS intercepts requests for "orbilogin.net", not "com".
I would trust the Orbi web interface over the "app".
Mstrbig
Aug 22, 2020Master
CrimpOn wrote:
Mstrbig wrote:
What does it show when you go to orbilogon.com?That may be a typo. I believe that the Orbi DNS intercepts requests for "orbilogin.net", not "com".
Yes orbilogon.com is wrong, meant to type orbilogin.com
orbilogon.com, orbilogon.net as well as routerlogin.net and routerlogin.com gives the same GUI results.
- CrimpOnAug 22, 2020Guru - Experienced User
Good catch of MY typo. I meant to type orbilogin.com, and whatever I actually typed came up with "You are not connected to Orbi network." Should have tried again.
Thanks
