ClancyS
Jan 30, 2023Aspirant
Parental Controls for Orbi 90 RBR350- HELP!
Can anybody advise me on why I can see Parental Controls in the Orbi App? I even download My Time App but it says I have to open the parental controls on the Orbi App! I'm going around in circles and...
ClancyS
Feb 07, 2023Aspirant
Which Orb i app is this?Android? iOS? The app is on IOS, could that be why I cant see parental controls?
What is the firmware on your RBR350? I don't know how do I get this info?
Ok I'll also post to the other community thanks!
CrimpOn
Feb 07, 2023Guru - Experienced User
If using the Orbi app, press on the menu in the upper left corner of the screen, then select Settings.and then Router Settings.
The firmware release number is just above the serial number.
For a long time, I did not realize that the app screen had more "panels" than would fit on one screen. Scrolling (up? down?) brings up the rest of them. Maybe on your app the Parental Controls are "down below"?
When companies package WiFi systems for home use, they want to prevent customers who live close to each other from having the same default WiFi name (SSID). Netgear names each system with the letters "ORBI" plus a two digit number (in your case "90"). Since I have had WiFi for 20 years or so, I always give each new WiFi system exactly the same SSID & password as the system that is being replaced. This saves me some effort because:
- Every WiFi device immediately connects to the new system without me having to set it up again, and
- If I decide to "go back" (maybe the new one is a dud), when the old router starts up, all the devices connect to it immediately.
- ClancySFeb 15, 2023Aspirant
I tried scrolling up and down no parental controls to be seen đ
