stand3476
Jun 10, 2024Aspirant
Parental Controls RBR 850
I have parental controls on and 2 devices continue to show up with a gray dot as if they are offline, yet they both are connected to wifi to the same network that my orbi is monitoring and are able to...
Jun 11, 2024Guru - Experienced User
And what are these devices that show up as gray dot?
Can you post a screen capture to see?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
stand3476
Jun 11, 2024Aspirant
the two devices are a dell laptop and a ms surface
