Dewms26
Jul 09, 2022Aspirant
Phantom device
How can I remove a phantom device from my Orbi Wi-Fi network? It is online but I don’t recognize the device name. ANDROID-A2E3D40A148233E1. Any suggestions?
- Jul 09, 2022
Dewms26 wrote:
How can I remove a phantom device from my Orbi Wi-Fi network? It is online but I don’t recognize the device name. ANDROID-A2E3D40A148233E1. Any suggestions?This is almost certainly an Android device which has the option Randomize MAC turned on. This is defined an an additional option for each WiFi name in the Settings table. (Click on the Gear Icon, then open up the additional settings.) This means the MAC address presented to the Orbi is not the actual hardware MAC address of the device WiFi and thus it will not match anything that you may have entered into the LAN setup table. Orbi has recognized that it has an Android operating system and has created this goofy name which is a mashup of 'ANDROID-" plus the MAC address.
If you change the device network settings, it will appear as it did before. This new 'security' feature of randomizing MAC addresses is supposed to make us feel secure, but (in my opinion) is more of a bother since every time the device updates software, the option gets set back to Randomize. Oh, well.
schumaku
Jul 09, 2022Guru - Experienced User
MAC address? IP address?
