Chuck_M
Oct 13, 2020Mentor
Phantom Satellite On Phone App
My RBR850 with 1 x RBS850 and 2 x RBR-50s (hardwired) is working great. However.... On the android Orbi app I clicked on Network Diagram and got the expected "tree" of the router and thre...
- Oct 14, 2020Had the same problem, only fix was a full reset and to not use a back up config file... Had to put all my settings back from scratch. Royal pain in the a$$.
Only recommendation from Netgear was uninstall and reinstall the app which did nothing to help.
KMDonlon
Oct 14, 2020Virtuoso
- Chuck_MOct 14, 2020Mentor
Only recommendation from Netgear was uninstall and reinstall the app which did nothing to help.You were spot on.
I did a full factory reset and reconfigured by hand.
Phantom satellite is gone and everything is working fine.
Thanks much for advice.
