tpgnavy85
Mar 18, 2024Tutor
Potential Renaming Bug in Orbi 970 Firmware
This report is actually for the Orbi 970 product, running latest firmware. Newly installed this weekend, and one of the attached devices cannot be renamed at all in the browser interface. Refuse...
- Mar 18, 2024
Ok. Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
tpgnavy85
Mar 18, 2024Tutor
Web UI is where I have been trying to change any attributes, to no avail. 2 different browsers from different platforms, and neither can change the attributes going into the Web UI for the router.
I will log an issue with Netgear as well, wasn't sure if they have engineers monitoring this community and may want to weigh in.
Thank you, tpgnavy85
Mar 18, 2024Guru - Experienced User
Check with the Mfr of that device as well. Possible they may not allow a change or the router is seeing that itself can't change it. Or could be a bug. Keep us posted.
