blackSP
Jul 11, 2020Aspirant
RB-50 network is running fine but app says 'no internet connection' - can not get into app
Like the title says, my RB-50 network is running fine but the orbi app on my huawei mate 20 pro says 'no internet connection' after I had to do a factorey reset of my phone. So I cannot get into app,...
Christian_R
Jul 24, 2020NETGEAR Employee Retired
Hello blackSP,
Does the same issue persist on another mobile device? May you provide the current app version you have installed on that device. You may also use the link the below to get in contact with our support team.
https://www.netgear.com/support/default.aspx
Christian
- blackSPAug 02, 2020Aspirant
Hi, thanks for responding. I almost gave up on the RBR50's so I stopped checking here. I'll install the app on a friends phone to check if it works there. I'm running the latest app from google play (2.6.0.1214). FYI, I run quite a lot of connectivity apps, also for my work's networks, and Netgear is the only one that gives this problem. Will get back soon!
OK, just installed the latest version on a Huawei Mate 10 running Android 10 and it works fine there.
On my Huawei Mate 20 running Android 10.1 there's no way I get ot to connect to my network, whatever I do it says 'no internet connection'. Obviously my phone is connected to my 250 mb/s wifi network, just as 6 or 7 other devices.I already cleard app cach, dalvik cache, reinstalled the latest 10.1 rom trough e-recovery, uninstalled, reinstalled the Orbi app.
So, what's next?
I can contact support but I rather have a public discussion so others can benefit for the results.
Thanks,
Rob
- blackSPAug 18, 2020Aspirant
I'm selling the overprized Netgear Orbi RB50 rubish routers.
Know why? Because Netgear does not care about their customers.
You pay an awful amount of euros to get the 'best of the best' and than trouble starts with no help from the company.
Very sad.
