BrooklynOrbi
Mar 06, 2020Aspirant
RB50 "No Connected Device Found"??
I recently updated the firmware of my Orbi RB50 system. Now, in the Orbi App, when I go to the Network Map and click on the RB50 or one of the satellites to see which of my devices are connected to w...
SLK-Purdue
May 21, 2020Luminary
2.5.1.2 but pretty sure it is not an app issue. SOAP data from FW 16 is the problem.
Christian_R wrote:
May you provide us with the current app version you have installed on your mobile device (iOS or Android)
Christian
Christian_R
May 22, 2020NETGEAR Employee Retired
Hi SLK-Purdue,
We recently released Orbi app version 2.5.2.1. May you reinstall the app and let us know how it turns out.
Christian
- SLK-PurdueMay 22, 2020Luminary
Will do and let you know.
Thanks,
Scott
Christian_R wrote:Hi SLK-Purdue,
Christian
- SundreamerMay 24, 2020StarNo luck here,
Using 2.5.1.8 plus latest app and no device
This is a mess- simonmannMay 24, 2020GuideDownload the firmware v2.5.1.16 for both router and satellite from https://www.netgear.com/support/product/orbi.aspx#download and update on each device via orbilogin.com
