Asrielkit
Oct 12, 2020Aspirant
RBK852 can't speed test via orbi app but can speed test with other app
Hello My RBK852 just setup 11-10-2020. FW aleady updated. I can use the orbi speed test when just finised setup. However, i tryed to test again few hours later. it doesn't work. "Connection F...
- Oct 12, 2020
Asrielkit wrote:I use the IPhone "Speedtest" app is no problem to check the speed but the speed test function in orbi app can't.
I have reset, power off and still the same problem.
The problem has nothing to do with the Orbi system. It is an IOS issue with the app. Make sure you are running the latest IOS, then reset your network and re-join the WIFI. You may have to uninstall and reinstall the Orbi app and reinstall it.
Asrielkit
Mstrbig
Oct 12, 2020Master
- Chuck_MOct 13, 2020Mentor
Are you able to run the Speedtest under the QOS section of the Web based GUI?
- AsrielkitOct 15, 2020Aspirant
Under the Qos can test the speed.
- FURRYe38Oct 15, 2020Guru - Experienced User
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
- AsrielkitOct 20, 2020Aspirant
Finally, i reset the RBK852 and restall the ORBI app. It works now.
