Jonnybunker
Mar 03, 2023Guide
RBR 750- Local Connection and Anywhere Acess issues
Is anyone else having issues connecting through the Orbi app via local connection or Anywhwrre Access ? Local- getting logon timeout Anywhere : Device offline message I can connect to my RBR50 ...
- Mar 04, 2023FML
Put my gateway in Bridge mode , and it fixed the local connection issue immediately with orbi app. Also seems to be running much faster.
I can no longer reboot my modem remotely though as Xfi disables all their features when in Bridge mode but I think being able to remotely manage my router is more important than my modem.
Thanks for everyone’s help
Solution : Do better research originally haha and follow best practice of Orbi recommendations and XFINITY recommendations. Set ISP in Bridge mode and allow Orbi to handle NAT
I feel like I have wasted 20 hours chasing my tail.
Mar 03, 2023Guru - Experienced User
Be sure you have any MAC Address randomizers disabled on your mobile devices:
If you still can't get in, please submit a bug report using the Orbi app:
- JonnybunkerMar 05, 2023Guide
Hey Furry38, do you know if there is a way to disable Netgear Armor from 192.168.1.1 Admin page on a computer, from Netgear.com or from Armor.netgear.com? I don't have access still and wondering if that is the probelm.
I can always do a full factory reset again, and try disabling it, but don't have time to do that right now, my wife might kill me
