rleone31
May 09, 2022Follower
RBR 750 Unable to connect to router
I keep getting the error message "We can't find your Orbi". I have unplugged the internet cable, unplugged the Orbi, rebooted the system and it still does not connect. I don't know what else to do. P...
Sauzarob
May 13, 2022Aspirant
I am also having this same issue. Is there an update on a resolution? I tried the work aroudn but that was unsuccessful
Thanks,
Rob
MasakiKoi
May 13, 2022Star
Work around it is to do a hard reset (factory reset).
Netgear if you are reading this.....The new Orbi app update for the iPhone last night 5/12/22 did NOT solve the problem!!!!. Orbi app version 2.17.0.171. App still not able to connect to router.
Error message......"We can't find your Orbi". Fix it please!!!
- FURRYe38May 13, 2022Guru - Experienced User
