Venturer51
Jul 30, 2022Tutor
RBR 750
My satellites appear to have been synched but show as offline in orbi app. How do u tell if they are working properly?
Aug 01, 2022Guru - Experienced User
Are they appearing as synced and connected on the RBRs web page?
Venturer51
Aug 01, 2022Tutor
They appear connected in the orbi app but do not know if they are also synced. In the app it says they r offline.
- FURRYe38Aug 01, 2022Guru - Experienced User
What does it look like on the RBRs web page under Connected Devices?
- Venturer51Aug 01, 2022TutorThey appear to be connected in the system but when I go into the satellites, they say no connected devices found and show as offline.
Can you post a screen capture of the RBS web page?
Edit out the SSID name before posting.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
