Fdmark42
Aug 12, 2023Follower
RBR NETWORK MAP
My network map shows both RBS connected in a straight line with solid lines and green dots. Should I have dotted lines to the RBS? Thx
Aug 12, 2023Guru - Experienced User
No. The blue lines just mean the connection direction now days.
Look at the green icon on each unit. The wifi icon means the RBS is connected to the RBR wirelessly. IF you had the RBS ethernet connected, this icon will change to <->.
