PhilBeard
Mar 15, 2020Aspirant
RBR50 Connection Problem with iPhone
I tried to install the latest firmware update to my RBR50 router through the Orbi App on my iphone. The app tells me that I am not connected to the router even though I am using the wifi network prov...
- Mar 19, 2020
Hi PhilBeard,
You may need to factory reset the Orbi router by holding down on the reset button for 15+ seconds. You will need to run through the setup assistant again.
Christian
PhilBeard
Mar 18, 2020Aspirant
Thanks. I tried both but neither solved the problem.
Christian_R
Mar 19, 2020NETGEAR Employee Retired
Hi PhilBeard,
Christian
- PhilBeardMar 20, 2020Aspirant
Christian, thanks for taking the time to respond. I finally resolved the problem by doing something I should have tried early in the process; i.e., I power cycled the router. Given how common and how simple the solution turned out to be I'm feeling pretty dumb for not having tried it before turning to the community. Thanks again for your suggestions.
- Christian_RMar 20, 2020NETGEAR Employee Retired
Hi PhilBeard,
Happy to hear!! Have a great weekend!
Christian
- WallStWizKidApr 09, 2020AspirantYou mentioned you “power cycled” the router and that solved the problem. Did you mean you got a safety pin and hit the reset button for a few seconds? The reason why I ask is I’m having the same issue. Never had a problem and all of a sudden my Router will not connect with my internet yet my satellites are connecting to my Router ok.
- PhilBeardApr 09, 2020Aspirant
I unplugged the router, waited 60 seconds, then plugged it back in. After it rebooted all was well. Good luck.
