saagar
Jul 19, 2020Follower
RBR50 Orbi App Connection
Hi all, I am trying to go into my Orbi app on my iphone and it keeps taking me to the admin login screen. I don't recall every changing the password so I tried "password" as default and no luck. ...
Jul 20, 2020Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in until the top led turns on AMBER then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
Now open Orbi app and use the same admin name and password you just set up for the RBR. The app should log in for you.
