Mamagear
Feb 21, 2024Follower
RBR50
I have the RBR 50. The ethernet connection to my router will no longer connect. Is there a reset or something else that will make this reconnect? I have tried the reset on the back of the 50. I have tried unplugging the Internet and the router and restarting, none of this is work
1 Reply
there's multiple ethernet connections on the back.
Are they all non-functional?
Just the WAN port?
Just the LAN ports?
What modem/gateway is it connected to?
How do you know it isn't working?
Are you able to log into the orbi and check its wan port statistics page?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
