TeddyT
Nov 30, 2022Aspirant
RBR50v2 – unable to connect remotely and issues with SPC
I am having issue connecting remotely to RBR50v2 router from the android Orbi App. Getting error “we can’t find your orbi”. It only lets me connect locally and Internet runs fine via router. Updated ...
TeddyT
Yes anywhere access is enabled and internet connection is working from remote location. On app from remote it shows RBR50 being disconnected when actually it is connected
CrimpOn
Nov 30, 2022Guru - Experienced User
(Trying to follow this...) The Orbi app works remotely. Displays information about the Orbi system. Claims that the system is "Disconnected". i.e. that it is not connected to the internet, when obviously it must be connected because the Orbi app has gathered information about it???
I thought the problem was "we can't find your Orbi".
I have never figured out what the Orbi router does to decide that it has an internet connection. My guess is that some program in the Orbi firmware attempts a connection to some specific URL (maybe http://netgear.com , who knows?). If there is no response, then the router says "No Internet", which it relays to the Orbi app.
Sorry to be so confused. I'm not sure I know what the problem is.
- TeddyTNov 30, 2022Aspirant
It is when I chose “connect to a different product” I see RBR50 as disconnected. Main issue is “Unable to connect to router” when trying from remote. One new error screen I'm seeing under we can't find your orbi is “ your Orbi may be in bridge mode… Turn Bridge mode off and try using the app again”. The RBR50 is configured on Router mode and I haven’t configured any bridge mode. Do you think downgrading firmware will help ?
- KevinLiTDec 01, 2022NETGEAR Moderator
Hello TeddyT,
Welcome to the NETGEAR Community!
Which Orbi app version do you have currently installed on your mobile device?
Best,
Kevin
Community Team
- TeddyTDec 01, 2022AspirantHi Kevin
I just upgraded app to 2.21.1.2602 but remote access still not working. I also did 30/30/30 reset reinstalled app same issue.
