ron111157
Apr 09, 2023Apprentice
RBR50v2 Problems with the phone app
RBR50v2, RBS50v2 and RBS50, version 2.7.4.24, Apple IOS & OS. App version 2.25.0.44 After the last couple of app updates I have been having problems with the phone app. It will show I am conne...
Apr 09, 2023Guru - Experienced User
Also:
- ron111157Apr 09, 2023Apprentice
Thanks for the info. I did not know about the report-a-bug for the app. I have submitted one now.
I was aware that a newer FW update was out there but as many have said it does not show in the update tab on the web. I have seen that post before. I have downloaded the updates but am reluctant to do a manual update given the problems people have talked about in the post. The last thing I want is to have to do a factory reset and go thru all that reloading and rebuilding again.
I have went thru several updates (most auto, one manual). All those went smoothly so far.
I don't use Armor or SPC and my laptop page works fine. The phone app has the latest update so I'll wait to see if the bug fix route helps before I move forward.
- FURRYe38Apr 10, 2023Guru - Experienced User
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-System- ron111157Apr 12, 2023Apprentice
I do have a recent CFG file saved. Thanks
As for the original problem/issue It has resolved and the phone app is working properly again. Never heard anything back on my Bug report But hey it works now soooooo who knows.
I was browsing around the site and reading posts and it seems there were multiple recent issues across the Orbi family. Good to hear that most have resolved.
