miketheknight20
May 06, 2022Apprentice
RBR750 Shows Offline After FW Update
I just updated the FW on my RBR750, and now I am unable to access the orbi via the app, or by IP (192.168.5.1). I have deleted and re-installed and logged back into the app, still unable to conne...
- May 31, 2022NG must have pushed the update to me. I can now access everything via the browser. App just spins when I put in the password in and I assume times out, but I may need to delete and reinstall. But that will be a tomorrow project.
Just excited that I got a win!
May 06, 2022Guru - Experienced User
what modem/gateway do you have?
Why are you changing its ip address to the .5.1 address?
- miketheknight20May 06, 2022Apprentice
plemans - it's the default one that my ISP gave me.
I'm changing the IP bc I work from home and 1.1 and 2.1 are being used by work and it's easier if I change my home range to 5.1 (or even another number)
Everything was working perfectly 'til I logged in and updated the FW
- plemansMay 06, 2022Guru - Experienced User
whats your full setup?
modem:
how many routers/dhcp servers are you running if you have a 2.1 and 1.1 already in use?
A better idea of what your routers/servers/whatever is on your network helps.
- miketheknight20May 06, 2022ApprenticeOne ISP modem, then the orbi router acting as the standalone DHCP
I connect to work thro vpn and when connected if my personal devices are on the range it causes conflicts.
But all that is on play is ISP modem and orbi router plus the two satellite
